welding stainless steel?
- lightning_msd
anybody know how about doing this? or what type of welder to use? i was thinking TIG, but i wasnt sure, i just want to weld a tip on the end of an antenna im making. i dont have a tig, i only have a mig and an arc.
1967 F100 "Lexxi" 352
http://www.fordification.com/galleries/ ... ?album=482
- MadMaxetc
re: welding stainless steel?
you can do it with a mig, you just have to get the SS wire and different sheilding gas. You can do it with nornal steel, but the welds will NOT be SS
Dan
FORD Girl
Photobucket Pictures
FORD Girl
- averagef250
- lightning_msd
ya its just for a tip i made to put it on, i was almost thinking just sodering it on,
- averagef250
- lightning_msd
thats the thing, its not a bulb type dealy thinger majig, i made a lightning bolt to put on the tip. i did drill a hole, but i drilled a bit to big so it just slides off. jb weld is probably the way to go, never considered that, i have a few tubes around here somewhere. thanks 250
