welding stainless steel?
lightning_msd
Post by lightning_msd »
anybody know how about doing this? or what type of welder to use? i was thinking TIG, but i wasnt sure, i just want to weld a tip on the end of an antenna im making. i dont have a tig, i only have a mig and an arc.
MadMaxetc
re: welding stainless steel?
Post by MadMaxetc »
you can do it with a mig, you just have to get the SS wire and different sheilding gas. You can do it with nornal steel, but the welds will NOT be SS
Dan
FORD Girl
Photobucket Pictures
averagef250
Post by averagef250 »
Converting your mig is a spendy deal for welding the tip of an antenna on. Go buy a piece or two of 1/16" 309L stainless rod and stick it. Makes prettier welds than stainless mig anyway.
lightning_msd
ya its just for a tip i made to put it on, i was almost thinking just sodering it on, :lol:
averagef250
Stainless does not solder in the usual sense. You will need some specialty solder $$$ to get the job done.
Can you make the ball an interference fit to the antenna shaft? JB weld?
lightning_msd
thats the thing, its not a bulb type dealy thinger majig, i made a lightning bolt to put on the tip. i did drill a hole, but i drilled a bit to big so it just slides off. jb weld is probably the way to go, never considered that, i have a few tubes around here somewhere. thanks 250 :thup:
