Alternator question
wildcard
Alternator question
Post by wildcard »
On a 300, which connection does the pos. clamp go to to check output voltage?
splavin90
re: Alternator question
Post by splavin90 »
the thicker wire goes on + and the smaller one goes on F
69 F100 81' 302 / 73' fmx
wildcard
Post by wildcard »
wildcard
Post by wildcard »
OK, this may sound a bit odd but here goes.
It seems when the engine is running, something is drawing power down. To about 11.9 volts. After it sits a while not running it gradually goes back up to 12.5 volts. I actually watched it do that. I know I haven't had much sleep lately but .............
Also when it runs a while it won't start back up for about 10 min. Then starts with no problem. Acts like a dead batt until it cools off a few min. All this on a new engine.
QC
Post by QC »
Your alternator is not charging. You are just reading battery voltage. The battery will recover a little on it's own, but it is going to get progessively lower until it's too low to start the truck.
69 F-100 Ranger 302
wildcard
Post by wildcard »
It's a brand new alt. I got yesterday and the old one was doing exactly the same. I'm gonna try to go get the batt. and alt. checked this morning. I'll let you know what I find out.
ToughOldFord
Post by ToughOldFord »
Don't forget the regulator.
wildcard
Post by wildcard »
I took it to AutoZone and they checked the battery and regulator. Both were bad. It still won't show any more than 23.3 volts. That's with the engine off. 11.8 with it running. :dk: I've double checked the hookups on the alt and they are ok. I've about replaced everything now so it may be in the wiring. Any ideas where to start looking?
wildcard
Post by wildcard »
That should of been 12.3 with the engine off. :oops:
maybe the wiring was hooked up wrong on the alternator. did it work before the engine swap?
wildcard
Post by wildcard »
As far as I know it worked before the swap. Never had a problem that I recall. I took a pic before I unhooked it to be sure it went back right.
I did wash the engine bay with a pressure washer prior to install.
ICEMAN6166
Post by ICEMAN6166 »
is there a fusible link in the harness on that?
i see it in the 70 diagram.you would still have all your other power items working except charging if it was bad.
wildcard
Post by wildcard »
Yes, it does have one. Could I bypass it by cutting it out? Or use a jumper wire to go around it to see if it makes a difference?
yuo could try just temporarly bypassing it until you figure out if thats whats bad or not. if it is bad then you are suppose to replace that link wiht the proper size wire to recreate the fuseable link. sorry i don't know which size that is.
wildcard
Post by wildcard »
Tried it. Didn't work. Looks a job for a prpfessional.
