leaf spring bushings
jirik68
Post by jirik68 »
When you guys repaced your rear leaf spring bushings what is the best way to get them out and if i have to cut them out do the flex-o-matic rear suspention take different bushings than the other because the parts store never asked me what suspention I have when calling for prices
heep70
Post by heep70 »
Burn them out.
Don't know if there is a difference in bushings.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
re: leaf spring bushings
Burning them out with a torch is probably the easiest way. If you don't have access to a torch, you can just drill out the rubber and then bang out the steel sleeve. That's how I did mine....I've got some pics posted of the process at the following link:
http://www.fordification.com/my67-p28.htm
i thought someone said you could press them out. maybe i'm wrong
wt4speed#2
Post by wt4speed#2 »
Yea they are made to be pressed in and out but if you dont have a hydralic press might as well burn em out . I had mine done all 6 bushings in and out 85.00
Tony B
Tony B.Image
DFW Area
"Someday...
I hope you to get the chance,
to live like you are dying"
Member#'s 236 & 403
Úlf the Comedy Sidekick
'69 F-100 "Stepper"(currently in a bigillion pieces )
wt's ride
thebucket
ICEMAN6166
Post by ICEMAN6166 »
i use a fire-wrench.
if you dont like burning rubber (or have picky neighbors) go to a spring shop.
