rear end
re: rear end
nope, not without extensive modification.
When the going gets tough, your doing something right.
- ICEMAN6166
re: rear end
what gears are you looking to have? the 9inch and dana 60 both had numerous stock choices.
re: rear end
If its a 9" just change the pumkin and be done with it. Just make sure the axels have the same amount of splines as yours .
Foggy
Foggy
re: rear end
It's a Dana 60 with 4:10 now, and I want it to run with some longer legs, she's whining real loud at 60mph. I would like to get 3:54/55's witchever it is, I've seen both listed but I don't know if it's actually the same ratio or not
I appreciate the info, I need all the help I can get.
Fossil
Fossil
The ONLY true thing WE OWN and have to GIVE is our WORD. I did what others did not want to, and became what others could not, now the best "REVENGE TO WAR" is to live the best I can.
- 72hiboy4x4
I have a dana 60 with 3:73 gears in it, and its got one of those factory locker/limited slip things in it.
Out of a 71 F-250 crew cab, used in my truck for 2 years before I swapped to a dana 70.
Make me an offer if it will work for ya and I can deliver it to Vancouver or possibly closer.
- ICEMAN6166
Re: re: rear end
a 4.88 rear at 100 mph is loud.Fossil Dawg wrote:It's a Dana 60 with 4:10 now, and I want it to run with some longer legs, she's whining real loud at 60mph. I would like to get 3:54/55's witchever it is, I've seen both listed but I don't know if it's actually the same ratio or notI appreciate the info, I need all the help I can get.
Fossil
my 4.56 i can drive 65mph in 4 high with no noise.
i prefer 4.10 or 4.56
my wife has 3.50s in hers, it is very fast but lacks the traction of the
others going thru the snow and climbing hills on a slippery road.
i think a 3.73 is a good median between them, especially with a locker.
it really will depend upon how you drive and use your truck, and the terrain where you live.
re: rear end
72hiboy4x4, I would not have any idea what it would be worth
how about giving me a pm with a starting figure and I'll let ya know if I can swing it, I only get paid once a month from uncle sam. Let me know.
Fossil
Fossil
- FLATBEDFORD
How many miles does it take you to stop when you're going 85?kid wrote:4.10s on my 350 at 4400 is 85. It will be going down to 3.58s soon.
Steve
My Photo Gallery
My Photo Gallery
Stops on a dime well almost until the left rear wheel cylinder blows out.
12*3 brakes if moved to a F100 would rip the axles off if you had a F350s loaded weight on the light weight F100 chassis.
I just got back from a highway run on the F250 (still coming together) and I was prompted to look under the tail and darn my Dana 60 is a 4.10. So the F250 gets it's gears first.
- cooltoolguy
re: rear end
72 Ford F-350, 2WD, 4 speed 360, Dump truck
76 Ford F-350, 2WD, Cab and Chassis <--gone
On another note since this was about a conversion. We built a Pinto wagon for an Officer in the Navy 302, 410 hp 4 spd and get this the rear end from a 72 Torino, 9 inch. The spring pads were 1/2 wider than the Pintos. We shimmed the mounts out a 1/4in on each side.
My first test launch after the break in and final tune lifted the front wheels in first and second.
:)He went home happy.
