I have a 66 f250 I am changing over to 70 f250 disc.
My question is if you diconnect the front lines at the junction block under the truck can you pull lines and proportioning valve from a 70 and install the 70 lines on the 66 with out any problems?
brake lines
- ICEMAN6166
re: brake lines
i think you can as far as thread size and length but if you are going to the disc and power i would buy new ones for a 70 with disc brakes.
- ezernut9mm
re: brake lines
anyone tried double flairing yet? is this a talent or can it be learned pretty easy? i need to try this out.
re: brake lines
Super easy, with the right tool, basically no different than a standard flare, except that you do it twice.
Here's something I put together when I did mine:
http://www.fordification.com/my67-p34.htm
Look down towards the bottom of the page for the mini-tutorial.
- ezernut9mm
re: brake lines
thanks keith. i'm sure the flairing tool will more than pay for itself over the cost of prebent tubing.
