mnyman wrote:Hi Wes,
.......Thanks for the advice on the bearings. I was planning to use my original bearings as they only have 31K miles on them. Is it hard to find replacement races?
Take care.
mark
i dont know about the races but when i fixed my 68 up in SoCal a small parts store (B&C? near pepper drive and hwy 8 in ElCajon) actually had everything i needed in stock timken bearings front and rear including the grease seals and rear axle nuts and washers hell they had the brake shoes i needed
i would think that they are still out there...i recall that berry bearing was bought out by another company so you may want to look into that but this is what i found on rockauto.com...maybe it will help ya some...
1968 FORD F-250 PICKUP
Item Price Core Total
BCA Part # 15245 {Taper Bearing Cup Outer Diameter=2.441" Length=0.5625" Radius=0.046"}
Front Wheel; Outer; Tapered Cup; (Disc Brakes); (RWD)
Front Wheel; Outer; Tapered Cup; (Drum Brakes); (H/D Brakes); (RWD)
$3.86 $0.00 $3.86
BCA Part # 25520 {Taper Bearing Cup Outer Diameter=3.265" Length=0.75" Radius=0.031"}
Rear Wheel; Outer; Tapered Cup; (H/D Brakes)
$6.64 $0.00 $6.64
BCA Part # LM29710 {Taper Bearing Cup Outer Diameter=2.5625" Length=0.55" Radius=0.046"}
Front Wheel; Inner; Tapered Cup; (Drum Brakes); (L/D Brakes); (RWD)
$6.86 $0.00 $6.86
BCA Part # A3 {Cone Length=0.55" Bore=0.8437" Outer Diameter=1.9687" Width=0.69 StoundOut=0.14" Cup Length=0.55" Cone Radius=1.046"}
Front Wheel; Outer; (Drum Brakes); (L/D Brakes); (RWD)
$7.18 $0.00 $7.18
BCA Part # 362A {Taper Bearing Cup Outer Diameter=3.5" Length=0.6501" Radius=0.046"}
Front Wheel; Inner; Tapered Cup; (Spicer 44-6FHD); (Spicer 44-6CFHD); (4WD)
$9.60 $0.00 $9.60
BCA Part # 15101 {Taper Bearing Cone Bore=1" Length=0.8125" Radius=0.031"}
Front Wheel; Outer; Tapered Cone; (Disc Brakes); (RWD)
Front Wheel; Outer; Tapered Cone; (Drum Brakes); (H/D Brakes); (RWD)
$9.86 $0.00 $9.86
BCA Part # 18720 {Taper Bearing Cup Outer Diameter=3.3464" Length=0.5313" Radius=0.062"}
Rear Wheel; Outer; Tapered Cup; (Exc. H/D Brakes)
Rear Wheel; Inner; Tapered Cup; (H/D Brakes)
Rear Wheel; Inner; Tapered Cup; (Exc. H/D Brakes)
$10.53 $0.00 $10.53
BCA Part # A35 {Cone Length=0.58" Bore=1.625" Outer Diameter=2.891" Width=0.77 StoundOut=0.19" Cup Length=0.58" Cone Radius=1.14"}
Front Wheel; Inner; (Disc Brakes); (RWD)
Front Wheel; Outer; (Spicer 44-6FHD); (Spicer 44-6CFHD); (4WD)
Front Wheel; Inner; (Drum Brakes); (H/D Brakes); (RWD)
Front Wheel; Outer; (Spicer 44-6CF); (4WD)
Front Wheel; Outer; (Spicer 44-6F); (4WD)
$11.38 $0.00 $11.38
BCA Part # A37 {Cone Length=0.5937" Bore=1.7812" Outer Diameter=3.0625" Width=0.781 StoundOut=0.188" Cup Length=0.5937" Cone Radius=1.14"}
Front Wheel; Inner; (Spicer 44-6F); (4WD)
Front Wheel; Inner; (Spicer 44-6CF); (4WD)
$12.64 $0.00 $12.64
BCA Part # LM29748 {Taper Bearing Cone Bore=1.5" Length=0.72" Radius=0"}
Front Wheel; Inner; Tapered Cone; (Drum Brakes); (L/D Brakes); (RWD)
$13.04 $0.00 $13.04
BCA Part # 368A {Taper Bearing Cone Bore=2" Length=0.875" Radius=0.14"}
Front Wheel; Inner; Tapered Cone; (Spicer 44-6FHD); (Spicer 44-6CFHD); (4WD)
$17.12 $0.00 $17.12
BCA Part # 18790 {Taper Bearing Cone Bore=2" Length=0.6875" Radius=0.14"}
Rear Wheel; Inner; Tapered Cone; (H/D Brakes)
Rear Wheel; Inner; Tapered Cone; (Exc. H/D Brakes)
$17.46 $0.00 $17.46
BCA Part # 18780 {Taper Bearing Cone Bore=1.8125" Length=0.6875" Radius=0.093"}
Rear Wheel; Outer; Tapered Cone; (Exc. H/D Brakes)
$25.89 $0.00 $25.89
ACDELCO Part # 387A {#09441046}
CONE,RR WHL BRG INR DANA/SPICER 60, 61, 70 AXLES; CONE; 2 WHEEL DRIVE
CONE,RR WHL BRG INR DANA/SPICER 60, 61, 70 AXLES; CONE; 4 WHEEL DRIVE
**Non-stock item--shipping delayed up to 12 business days**
$32.99 $0.00 $32.99
i couldnt find any timken part numbers but maybe you can crossreference the BCA #'s
i kinda wish i had already swapped in the 79 F350 3.55 geared rear axle i'd let you have the parts you need off the 68 rear...
i doubt your willing to wait for me to get off my butt and do it
regards, James
