Do it yourself lift kit?
cghstrojan08
Post by cghstrojan08 »
Is there anyway I can lift my truck on my own? I have a 1969 f100. Lifting the back would be easy. Just add spacers on the leaf springs. How would I lift the front? Could I put a bigger spring in or put like a spacer in the top of the spring or I don't know. I don't want to but those kits for a couple thousand dollars. I am 17 and don't have the money but I would love to lift it. Also, can't really do any welding. Thanks!
ROBERT
Member #1076
1968 F100 SWB 360
72hiboy4x4
Post by 72hiboy4x4 »
A body lift is your only feasible solution.
Around $100
Heck just throw 33" tires front and rear, grab the sawz-all and cut out anything that hits!
boots
re: Do it yourself lift kit?
Post by boots »
I returned your PM, but the kit I made all involves welding. autofab.com is another solution... expensive but not thousands.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
hillbilly67
Post by hillbilly67 »
This is gonna sound pretty Mickey Mouse, but it works! Cheapest bodylift around is hockeypucks (how can you tell I'm fom Canada?) Pick up a dozen good ones from Walmart or similar, the sporting goods stores are usually more expensive. Get the hard rubber ones, not the sponge kind.
Drill 1/2" holes in them, maybe a handful of longer bolts and you are in business. Remember to watch lines, linkages, steering column and the fan shroud. Stack them for whatever height is req'd. You dont need a lot. It's suprising what an inch will look like.
I've seen them last for 19 years and still going.
Made my first million.....too bad it was mistakes..not dollars! Now pass me that crescent hammer.
72hiboy4x4
another idea along those lines, is to use polyurethane boat trailer rollers. supposed to work pretty good.
