AOD HOOKUP
AOD HOOKUP
I need some help with how to wire,and hook up the down shift cable up on my 68. The tranny is out of a 88 Crown Vic. there are 4 wires on the plug . Thanks in advance Paul
YOU GOT WHAT IN IT
re: AOD HOOKUP
I thought 80''s AOD's were non electric from hearsay. Hang in we have a few guys here with 5.0's in there trucks so help will arrive soon buddy.
re: AOD HOOKUP
The wire plug is for your neutral/backup light switch. The cable has to
be hooked up or it can ruin the tranny quick.
Go look on here--http://www.network54.com/Forum/260730/
Learn all ya can.
Learn all ya can.
- kknip
re: AOD HOOKUP
I put an early 90's model AOD out of a GT mustang in a 66 longbed a few years ago and never hooked up the wires,they are just that,the neutral safety and reverse light.The 66 did not have reverse lights and I always remembered that it would crank up in any gear.I drove the truck for quite a while with no problems.I fabricated a L shaped bracket that was mounted on the left rear carb stud-2 barrel-and ground a small screw flat on the head to snap the throttle valve cable into.Set the cable with some slack of course untill full throttle is applied to pull on the cable.I still have the trans and will try to find the bracket I made and take some pics of it after work today.
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
You knucklehead!
65 Mustang
re: AOD HOOKUP
Thanks for the help a pic of the bracket would be great. Since I am stuck on stupid here who knows how to hook up the alt. off of the crown vic on my truck.
YOU GOT WHAT IN IT
- kknip
re: AOD HOOKUP
Here is some pics of the bracket,note the small notch where it bolts to the carb,I made it to fit close to the carb and cut the notch out to keep the bracket from pulling to the side.Sorry the pics are a little out of focus,I'm still learning the new camera.
You knucklehead!
65 Mustang
You knucklehead!
65 Mustang
- Clarko
