Rear End Leaking
- cghstrojan08
Rear End Leaking
I have the Ford rear end and it is leaking fluid. The front plate (whatever it is called) is leaking. Is it the o ring? What is the easiest way to change it? Also, how hard is it to change the carrier housing gasket or whatever thats called? Thanks!
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
- cghstrojan08
re: Rear End Leaking
It isn't around the yoke. It is the 5 bolt plate. I don't know what it's called.
ROBERT
Member #1076
1968 F100 SWB 360
Member #1076
1968 F100 SWB 360
yep what he said it comes off and you replace that gasket
Your going to want to take of the yoke with an impact wrench after you pull the drive shaft off. Then you replace and seal with new gasket and tighten up. I am not sure if the fluid will pour right out so watch out or you might as well prepair for a differential oil change also. Good Luck
- kknip
Ewwww,anal seapage! If your housing to differential gasket is leaking,you have to remove the axles first and then all the nuts around the differential.
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
You knucklehead!
65 Mustang
ford 9 differential refill
I got this fliud tranfer pump thingie out at sears that I was going to use to put new fluid in. The refill nut/bolt has a recessed design on it like it might be hex drive or something. It could just be filled with grime though. Any idea what size and type it is?
69 F-100 2wd 360 cid C6
- 390Nut
3/8 inch square drive. A 6 inch extension on a 3/8ths drive ratchet works great for pulling that plug, but you want the area clean before you pull it out, so you don't get dirt inside.
You MIGHT need a breaker bar, or at the least a 1/2 inch drive ratchet, with a 1/2-to-3/8 adapter to break it loose the first time, if it hasn't been cracked loose in a long time.
Paul
`69 F100 390 4spd driver
- FLATBEDFORD
Make sure the vent tube isn't clogged. If its clogged, the pressure could push the oil through an otherwise good gasket.
Steve
My Photo Gallery
My Photo Gallery
- ICEMAN6166
theres vents in the transfer case and manual trans too and of course the front axle of a 4x4.
ever wonder why those items seem to be covered with oil when you first buy them?
