So my question is: Do I set the rear pinion inline (0*) with the driveline (ujoint end) while the truck is static (stationary). Or do I need to figure out what the degree of axle wrap is while in motion, then set the angle of the pinion short at static so that while in motion it will then change to 0*? Get it
What I have now is a 43" rear CV driveshaft.
T-case drops 2.5*.
Driveline tilts up at 16.5*.
Rear pinion points up 15*.
That leaves me with 1.5* difference from being dead nuts on at static.
I need to get the rear u-joint at 0*. Just not sure if it needs to be done in motion or static.
So, what do you know?
