I miss my Muncie 4 speed!
loveoldtrux
Post by loveoldtrux »
I used to love to drive my '57 Chevy Tudor with its' built 454 driving up highway 41.... the 5:13 rear just whining and the close ratio purring in my right hand.
I'd love to have something similar behind my built 460 in Harrison. The only thing the truck "hauls" now-a-days is perhaps a loaf of bread, so I don't tow anything with him. The C-6 is about to krap out on me (from an Econoline van), but has served me well through the years.
I guess the 2wd shortbed is a little heavier than the Tudor, but I'm wondering is there any setup for a "performance" 4-5 speed in these trucks? Again - the truck isn't drag raced and I don't tow.... I just miss the sound of a built 460+ in front of a manual tranny going through two 48" thrush mufllers....
I've seen many parts on e-Bay including the 3 pedal assembly and a variety of Bellhousings / clutches / hydraulic cylinders.... anybody happy with their "performance" system?....
REDNECKMOBILE
re: I miss my Muncie 4 speed!
Post by REDNECKMOBILE »
Do your Ford a favor and convert to a toploader. 5.13 gears and a big block for the road, what is all that about?
willowbilly3
Post by willowbilly3 »
I am a 3 pedal man too. My second "pickup" is a 429 with a big shaft toploader, still under construction though.
My everyday driver is a NP435 soon to be a ZF 5 speed.
Big D's 69
Post by Big D's 69 »
I love a straight shift but man it gets old sometimes having to shift gears.
fourtss
Post by fourtss »
Big D's 69 wrote:I love a straight shift but man it gets old sometimes having to shift gears.
never gets old!!!!!!!!!! 8)
tom
2003 ford escape
1997 dodge 1500 4wd 5speed, 1963 Cheby Corvair,
Georgia71
Post by Georgia71 »
In Atlanta traffic it does!
Larry
mjhaltom
Post by mjhaltom »
I would like to apologize for my GA neighbors. I will be sure and mail them a box of Kleenex. :evil:
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
19674x4
Post by 19674x4 »
you don't need a granny gear for a general driver, so rule out the np-435 and t-18. id'e say a ZF-5 speed and 4.10's
i'm a three pedaler to. i feel powerless driving an auto. i like to be able to control the rpm's and have the ability to shift at will. plus it makes for better burnouts
My Photo Album
Freightrain
Post by Freightrain »
I've converted both of my F100's into sticks(I hate slushboxes).
I put a nice wide ratio toploader in them and love it. Even in stop/go traffic it's pretty easy to drive.
Bump'n along.
averagef250
Post by averagef250 »
The ZF 5 speed is a granny tranny, it's almost a bolt in with a 460 though.
Jake11
Post by Jake11 »
2hr's in Kali. Traffic. Granny gear 4spd. Not so bad. 8)
averagef250
No kidding, I got stuck driving my '70 from Seattle to Olympia one Friday afternoon with a 16K lb trailer in tow. Burned 18 gallons to go 60 miles in 4 hours. Sure I would have burned half the clutch away and more fuel without granny.
adrianspeeder
Post by adrianspeeder »
Find a '88-'97 F-2/350 with the 460 if you want these ratios.
1st: 5.72
2nd: 2.94
3rd: 1.61
4th: 1.00
5th: 0.76
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
old timer
Post by old timer »
I am gathering up parts to put a four speed toploader in my long box.
I will need to use a two piece driveshaft, because of the length.
Rear driveshaft is no problem; but what about the front?
You need a sliding yoke to fit the toploader, but the front driveshaft doesn't slide. So you need to drop the hanger bearing to remove the transmission? Is there an easier way to do this?
averagef250
Why not just run a one piece driveline? Late 80's ford 1/2 ton vans used a really long single piece driveline that's real close to bumpside 2wd longbed length. Running two slip yokes in a driveline is asking for trouble.
