Ok the bird is having problems, Lately it is losing all power even straight from the battery. The starter, Alternator and all wires involved with it check out. The battery checks out as well. But i lose permanant power to the radio memmoryt and all the interior stuf lights and all shut off at kick over.
I'm thinking it may be the selniod shortung but it still gets power to the starer and ignition and fires over.
Any thoughts?
Powerloss at startup???
- rjewkes
- 72hiboy4x4
re: Powerloss at startup???
Bad connection at the battery. It may look good, but there is corrosion under the covering on the cables. everything works until you touch the key to start it, right? then it all shuts off?
Clean the battery connections and replace the cables, and you should be in working order again.
- rjewkes
ok should have mentioned I replaced the wires the first day this started and it did get a little better. Now it only happens when the car has been parked for 2+ hours.
one the newer for dtrucks the battery cable from ther soliniod to the starter becomes bad and has to be replacedbecause it looses connection and won't start at all. that is just something to think about even though it may not apply to your situation.
- rjewkes
yeah i'm down to the last two possabilities, The Volt Reg or the selenoid i'll try the selenoid first then if it persists the volt reg.
after that if it still has a problem i'll save the engine tranny combo and scrap the bird.
But its gotta be one or even both of the two becuase it'll crank it over and it'll fire but no interior or perm anant power until you disengage the starter.
- Wes
what year is this bird ? T-bird ? if its 80 up I would def check out the ign switch. they start to come apart after 6 or so years, even the new improved recall replacment switch. numerous car fires have been traced back to the switch Ford replaced millions of them 2 or 3 times. Got so bad they were on national back order for weeks. this applies to most all Fords 80 up except the mazda half breeds they have diff switch troubles.
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them![Smile :)](./images/smilies/icon_smile.gif)
67 F250 High boy
69 Bronco
- rjewkes
Thanks Guys. I replaced The selenoid apparently it was grounding out inside or atleast the post where it all ties in was.
So now it does everything better and it only seems to lose the power now when you crank for longer than 15 seconds.
It's like it drains the whole battery down, Then you finaly get it started and everythings good again.
So 'im going to do a tune up as it seems to be flooding now. And I'll check into that switch.
Wonder if i can get a whole ignition and lock set.
