Power disk conversion question
- kknip
What would happen if you did not change the manual 4 wheel drum porportion valve when you installed disk with a booster?Would it grab the front brakes too hard or possably lock up the back?
Soitenly! Oh,a wiseguy!
You knucklehead!
65 Mustang
72 F250 Camper Special
You knucklehead!
65 Mustang
re: Power disk conversion question
The drum brake piece isn't a proportioning valve, it's simply a distribution block, and using one in a disc-brake system will cause your rear brakes to lock up prematurely. Don't do it. Use the right pieces, please....for the sake of the other folks on the road at least.
- kknip
Thanks Keith,I wasn't sure,I will change it out as soon as I visit the pull a part junk yard to get one.Will it have the switch for the brake light on the dash?
You knucklehead!
65 Mustang
You knucklehead!
65 Mustang
Yes it will!
- Wes
Also if you can lower the brake booster apply rod 3/4-1" on the pedal, if going from manual to power brakes. manual brake have more mechanical advantage designed into them.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
- Wes
Yes with power brakes you don't need as much mechanical advantage to get the same applied pressure. A lot of classic and antique disc brake conv kits are not power, and the vendor discourage adding power booster. I have done 2 disc conv 1 on a Chevelle which I lowered the rod, and 1 on a mini truck which I didn't they both seem to work fine. I am putting a hydro boost on my 67 f250, and having to make a custom rod, trying an angled booster bracket
1st which should but the rod at 3/4" lower the original.
I know some folks are running big tires and need all the help they can get, so the original spot may work fine. I guess I should have really said make the rod 90 degrees to the booster and not worry so much about mechanical advantage.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
