who has the biggest?
Rear tire size?
on what size wheel?
with what backspacing?
on a two wheel drive truck, looking for info on anyone using tires bigger then 275x60x15.
pics?
on what size wheel?
pics?
- boots
re: who has the biggest?
36x12.50 on 15x10" wheels, 3.75" backspacing.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- Dropped 68
Running 295/50's on 10" wide centerline Hellcat's, not sure as to the backspacing, But I have decent clearance even for being lowered.
Charles
http://www.fordification.com/galleries/ ... ?cat=10451
http://s111.photobucket.com/albums/n146 ... =#imgAnch1
Build, Destroy, Rebuild!
Re: re: who has the biggest?
Well you beat me my 68 SWB it had 33*16.5*15s on 15 * 8 rims The turck sat stock height and I took a torch and removed the inside lip and flared the inner fender well to clear them.boots wrote:36x12.50 on 15x10" wheels, 3.75" backspacing.
- Randy Beck
The 275/60/15 are 28" tall. 325/50/15 are also 28"tall, just wider and will fit on 10" wheels. The 295/50/15 also will fit on 10" wheels but they are 27"tall.
1969 F-100 Ranger
351W/TCI Streetfighter C6-2800 stall coverter
Proline 180 heads
TorkerII intake/780 Holley
Sanderson headers/Flowmaster mufflers
Best 1/8th mile E/T 8.55
Best 1/8th mile MPH 85.024
Proline 180 heads
- customcrewcab
i have a 305 with tons of room but nothing is close to being stick except how wide the frame is.
on the 2wd f100 I use 31X10.5X15 on wagon wheels an all four, with no problems, it fills the wheel fully, but I would need to check my back spacing for I can't remember it.
I know the fronts are different than the backs on my truck.
WHAT ?
- CH3NO2
I run 285/75/16 which are 30" tall except the one I just noticed was going flat.I guess I better get off the computer & go fix it. Fun,Fun,Fun. Oh by the way their on 10" wheels with 6" backspace
Boots
Your truck looks great! I love it.
I only got 12"x16.5"s 32" across. Gotta lift the front a bit. They don't
like dips.
like dips.
- boots
Thanks!Jake11 wrote:Boots
like dips.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- 19674x4
oooh ahh ouch, cut fenders
back on topic, i have 33 ,12.5, on 16.5's with stock backspacing
My Photo Album
