Worn Tie-Rod Ends?
Worn Tie-Rod Ends?
What are some symptoms of worn tie-rod ends? Also, is there any way that I could check to see if the tie-rod ends are worn? I've got a wierd vibration going on in the front end and I'm trying to narrow down the possibilities.
re: Worn Tie-Rod Ends?
either that or bearings
- ToughOldFord
Jack up the wheel and grab the tire and shake it to your left and right. Do not pull truck down on yourself. Observe where the tire rod joint hooks up to the spindle arm, (if that's what it's called), if you see excessive movement, meaning pretty much any, then it's time for a new one.
- Galaxie64
When they get really bad you will be constantly correcting the wheel when going down the road, it usually is so gradual you don't relize how much correction you were doing until you drive it with new ends.
'68 F150 2wd
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
'56 F350 (engineless)
'48 F1 (Flat 6)
'51 F3 (Flat V8 )
Might not hurt to just replace them anyway, except they are a little expensive. If you remove the tierod ends from your truck, see if you can move them by hand. If they move without a lot of effort, they are worn out.
If they look like this, they probably should be replaced:
From a parts truck:
From a parts truck:
- ToughOldFord
Re: re: Worn Tie-Rod Ends?
Yep.bugser wrote:Nah,they just need a little grease.
Yup, those look like they have seen better days.
Two it takes to ck it out. One to wiggle the steering wheel back and forth
and another to eyeball the motion going on in the steering. Look at the
rod ends as your helper wiggles the wheel. Is there any lost motion or
"play" in them? If you see it or hear noise theres a problem. If you have
any doubts about a part being sub-par, replace it with new.
Be safe.
Also, your tires will last a lot longer if the front end is got tight parts. $$$
Be safe.
