http://cgi.ebay.com/ebaymotors/ws/eBayI ... gory=33679
That is the tach I bought on ebay. I know very little about wiring and electrical items. Will this tach require some type of transmitter/sending unit, or is it a direct hook-up to the coil?
Thanks,
Patrick
Sun Tach question
Sun Tach question
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
- turbocharged400sbc
direct hookup...
i wish they still labeled gauges that nicely...nowadays i cant seem to find the china connector....
1994 Olds 442 (425 cid-4 wheel drive-2 V6's) http://www.cardomain.com/id/94twinengine442 13.81 @ 98.2 MPH 1.9s 60's
68 F250 Camper Special 390FE/NP435/3.73D60
soon: 79 F350 disk brakes w/ 3.55 D60, pneumatic, 1750w AC inverter, Vector 1600w lightbar, 200A 3g alt, all a mobile gearhead needs
So the "trigger" connection goes to the + side of the coil? The ign goes to the
ignition switch? And I know the hole is for a light bulb.. should be able to scrounge one of those pretty easy.
Patrick
Patrick
Chevrolet
the ign switch is switched +mrsnicks wrote:So the "trigger" connection goes to the + side of the coil? The ign goes to the
Patrick
the trigger is the neg side of the coil...i think? (to the points)
- 68F250
I think the older two piece ones that needed a transmitter only had a (+) and (-) on the back. Street Rodder did an article on older Sun tachs.
http://www.streetrodderweb.com/tech/020 ... achometer/
Barry
re: Sun Tach question
Good find on the Sun Industrial Tach, I have one that goes to 6,000 rpms, still works like new from 1977.
Did you get the chrome can it sits in?
Check the calibration of it after it's installed, I have seen many that needed readjusted.
.....=o&o>.....
.....=o&o>.....
