I've just had a quick glance at the mounting brackets for the inner fenders- looks like some sort of rubber flexible mount? And it looks like one is missing and the other's trashed. I can't seem to find them in LMC or NPD.
Now, it's possible that my advanced age has me firmly by the tender mercies, but can anyone help me out with what SHOULD be there, and if I can buy replacements?
thanks.
fn
Fender brackets
- Fake Name
re: Fender brackets
if your talking about the lower inside of the inner fender there is a rubber piece that bolt to the inner and to the firewall. i have a set i don't need if you need them. or are you talking about the rubber that goes on the underside of the inner fender as a dust / dirt shield? lmc does have those i think.
- Fake Name
Re: re: Fender brackets
Yup that's them. Condition? Price?fordman wrote:if your talking about the lower inside of the inner fender there is a rubber piece that bolt to the inner and to the firewall. i have a set i don't need if you need them.
Thanks. BTW, you sold me a tailgate panel several months ago that looks GREAT on my truck.
fn
- 67F250CS
re: Fender brackets
I just cut two strips off of a truck mudflap and poked holes in them. Cost of mud flap Zero. I found it in the local truck stop laying up against the trash can. Its nice and thick like the OEM one.
Just a thought. I also used the rest to cushion the bed to frame bolts.
1967 F250 Camper Special
re: Fender brackets
they are in ok condition. 3.00 plus shipping. yeah i remember the panel i never heard back wheather you liked it or anything so i just figured you msut have not had any complaints. however the mudflap idea is a good one.
- Fake Name
re: Fender brackets
I probably will- not a lot of truck stops/mud flaps around here.
p
p
re: Fender brackets
either that or the sidewalls from a tire would work just as good. maybe even stronger than a mud flap
