I ran across this from another forum and thought I'd post it here, in case anyone was interested. Since I'm sure most of us know that the big truck (F-600/F-750) instrument panels come with circular gauges, I won't go into that here, but in addition to the vendors with similar panels on the
Links page, I've found another one. Check out the panel at the bottom of
this page at kustomcomponents.com. They're definitely pricey....but it's another option for someone who's not as....um....well....economically-challenged as I am.
This one appears to be only the center flat section for the gauges, in which you'd use your existing outer steel/plastic bezel/frame...and you even have to drill your own gauge holes. Seems like a bit much for a flat panel with some milled accents....but maybe that's just me.
