3 on the tree
AmericanMadeFord
3 on the tree
Post by AmericanMadeFord »
the other day i was driving down the road in 3rd gear and came up to a red light. i push the cluch in and went to put it in 1st but it was stuck in 3rd.
now my ? is can i just get rid of the collum shifter and put a flor shifter in and has any one done it ??
spartman
Post by spartman »
Yes they even have shifters for it.
Been done many many many times.
AmericanMadeFord
re: 3 on the tree
do they make a kit to do this. and if so whats a good one
spartman
Post by spartman »
Just look at either a B&M or a hurst.
BOth are good and can be easily purchased.
Just go to your local car parts store or order from jegs.com, summit racing, or whoever you like.
AmericanMadeFord
re: 3 on the tree
other that cutting the hole in the flor, is there any other cutting or welding or is it just a bolt together thing.
spartman
Post by spartman »
Pretty much a bolt in thing.
AmericanMadeFord
re: 3 on the tree
has any one ever convert there collum shifter to a flor shifter using a Hurst 3-speed Indy pick-up truck shifter
and if so did the kit come with everything you need or did you have to make/modify anything
frankc67
Post by frankc67 »
I have been looking into this also as future project. You have to watch which shifter kit you get some don't come with the boot/cover its extra $$....
http://store.summitracing.com/partdetai ... toview=sku
I want this one....
1968 Ford Pickup
1998 Ford F-150 extended Cab
2000 Ford Explorer
http://www.fordification.com/galleries/ ... ?pos=-1469
boots
Re: re: 3 on the tree
Post by boots »
AmericanMadeFord wrote:has any one ever convert there collum shifter to a flor shifter using a Hurst 3-speed Indy pick-up truck shifter
I have a hurst 3spd on my truck, I had to bend one top mounting peice just a bit. I just put it in my vice and pulled on it for a few seconds.
This is the one I bought, and i love it. http://store.summitracing.com/partdetai ... toview=sku
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
AmericanMadeFord
re: 3 on the tree
thanks for all your help. i ordered the Hurst Indy shifter from summit ill let you guys now how it turns out
