I was waiting for someone to ask if that power number was a typo or not...
Anyway, here's the buildup. I don't have an intake or headers for it yet, so I'm still open to options. Anyone have a 4 barrel intake they want to sell???
1993 4.9L block, .030 over
Forged crank, .020/.020
240 rods, ARP rod bolts
Keith Black #319 pistons (408 Windsor), with .070" milled off the tops. 14cc dish.
Speed Pro file-fit rings, low tension
Melling HV oil pump, screen, drive rod
ARP main studs
Cloyes steel timing set
The shortblock is pretty basic, the only tricks are the low tension rings, and the 240 rods (the 240 rods are longer than 300 rods, so it allows you to use a shorter, lighter piston).
The big power is going to come from the cam and top end of the engine. The head is a stock Ford casting, I'm not sure what year. It was ported by one of the cylinder head instructors here at the school.
230 cfm @ .700 lift
1.850/1.550 intake and exhaust valves (Manley stainless steel)
chambers reworked and head milled for 65cc chambers
Custom Comp Cams solid flat tappet cam, 248/254 @ .050, 110º LSA, .566 lift
Isky Gold Stripe double springs w/ damper, 133 seat/330 open
Head machined for 7/16" screw-in studs and guide plates
1.7 ratio big block Chevy roller rockers with Poly-Locks
You have to remember that this is a large bore/large stroke engine in stock form. If it were a V-8, it would be over 400 inches. So, when selecting a cam for this thing, you have to cam it like you would a 400 inch engine with reletively decent heads.
With 230 cfm of head flow on tap, and over 240º of duration @ .050, this engine will pull to 6500 rpm+ given a good 4 barrel or multi-carb intake and headers.
For exhaust, I'm going to go with single 3" pipe, routed where the stock exhaust goes, and exiting in the stock location. I'm going to run a big Dynomax RV muffler (36" long case) to quiet it down to as close to stock as I can get. I'm going to leave the rest of the truck looking completely stock, including the steel wheels and hubcaps.
With 375+ horsepower and a 3.70 gear in a light weight short bed truck, it should be really fun to drive!!!
Nick,
School of Automotive Machinists
I should be assembling this engine next week; I'll be sure to snap some pics for you guys.
