I have something really embarassing to admit. The cork or whatever type of weatherstripping that is at the bottom of the windows looks really old and crappy and leaves a huge gap in which for water to pour into my door from. Also, You can roll down my windows using your hands from the outside of the truck. The windows are also very rattly in the door. I was wondering how to replace this. I know I don't have to replace the vent window weatherstripping which is a GREAT thing, but I was wondering if this is a hard undertaking. I looked at the tutorial in the online dennis-carpenter catalog, but that is for the vent windows.
1969 f100 swb ranger 460 - parting out
1968 f100 swb 429 - decking out
94 Jeep I6 Back-up vehicle
reppin' AK
You can buy new seals from a number of sources and they aren't too bad to put in. The hardest part is removing the window. After that you just stuff the new seal into the track.
jor
As for being able to push your window down from the outside, that would be your window regulators....sounds like they're extremely worn out. Sounds like another run to the salvage yard.
'67 F-100 2WD SWB ~ '69 F-100 4WD SWB w/7" chop ~ 1975 F-250 Ranger XLT Supercab Camper Special My '67 restoration video -> Posting and you!<-a MUST watch for all!!
1) Remove the door panel
2) Remove the 4 bolts holding the regulator to the door panel and gently lower the regulator/glass assembly down to the bottom of the door.
3) Slide the regulator off the glass channel and remove through the access hole.
4) Remove the door fuzzies (since the glass assembly won't fit up through there with them in place).
5) Slide the glass up and out.
When removing the door glass you'll also have to remove the vent window assembly to get the door glass out, which is only a couple screws on the top and one nut on the bottom of the channel.
Funny thing this topic just so happens this is what I spent my weekend doing . Was in Okie City on Wednesday last week, neat place a little pricey butlike 7-11 was a "convience" thing, picked up the kit for window anti- rattle could have order it from LMC about 30 bucks less .but like i said "conveince".
This whole ordeal started while I was out scavanging for my 302 engine stands , I came across a set of premo wing window assys. all ruber in I'd say 90% condition picked them up aswell as a set of factory seat tracks , complete matching color seatbelts less right side retractor for $50.00. installed wing window assys and run channels dividerbar runs and anti rattle runs or glass wipers as i think they should be called in a couple of hours per side . If your gonna take the time to tear it down clean regulator and squirt lubriplate in every hole you can,it makes a great difference. I actually did left side on thurs nite,when I went and got 302 stands Friday I got left a side window regulator (a very rare scrap yard find) in about 4 times better shape than mine,so ended up taking down left side again worth the effort.And low and behold put right side back together window wouldn't go up or down with out great effort , pulled back down lubricated crank housing teeth on lifter and roller and wow. Every task worth performing .
I picked up stands , window regulator left side, wiper resivoir ,and door seals out of 89-90 exploder perfect fit,for $10.00 bucks , 85% of trucks rattles gone, no more wind tunnel syndrome at highway cruising altitude.
Thanks a lot keith for the information. My truck is in the shop right now getting the rollpan welded on all nicely, and some replacement motor mounts fabricated, along with new rubber since mine was cracked. So I won't be able to get to it for a few days. I am kind of upset because we've accumulated 12 inches today in snow and its still going!!! Does anyone have any window regulators I may buy, since u suggested mine are worn out. Also, another newbie question. Does anyone have a good suggestion as to how to get the armrest off without mutilating it? This is to get at the door handles to remove them, of course. Or an idea of the size those bolts are supposed to be, becuase the break in the rest to access them is tiny and I cant see much.
reppin' AK
Use a nut driver or a deep socket 'cause a short one will disconnect from the extension when you pull it out and get stuck in the hole.
Been there, done that! Now I ONLY use nut drivers. Those sockets are a major PIA to get out out once they get stuck in there.
shrektruck wrote:Sure, but if you leave one in each hole they're a lot easier to get off next time!
That's true!
