Paint over por 15
gonzalo medina
Paint over por 15
Post by gonzalo medina »
In order to paint over por-15 you must use a etching primer over right? Which brand is nessesary to do this. I just treted my floor board with that stuff and now I simply want to paint it back to the original color.
mrsnicks
re: Paint over por 15
Post by mrsnicks »
According to the por-15 website:
" CAN I PAINT OVER POR-15 WITH OTHER PAINTS?
Absolutely. POR-15 will accept all paints, including lacquer-based paints. POR-15 Tie-Coat Primer is the best prime coat to use before topcoating POR-15. Be sure to read thoroughly our directions and tip sheets regarding topcoating before using POR-15."
http://207.97.241.136/PRODUCTS/PRIMERPA ... fault.aspx
Don't know if too many people have not followed the recommened instructions and used a different primer. I know Keith paints his while it is still tacky to avoid having to use a top coat over the por-15 when painting it.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
Self etching primer just runs off of it. You will sand your fingers to bloody nubs before you rough it up enough to accept a top coat if it is dry.
Use the tie coat primer...
flyboy2610
Post by flyboy2610 »
And next time topcoat it before it dries completely.
