Wheel Spacers to run Mags on 69 Ford F250 4x4
ssteph1984
Post by ssteph1984 »
I bought some used 16 inch 8x6.5 pro comp mags. They have 4 1/2 inch back spacing and hit the tie rod ends. I measured the backspace on the 16 inch split rims on the truck and they have a 3 1/2 inch back space. Lugs are 1/2 and bolt pattern 8x6.5. I want to make the wheels work. Is there a set of wheel spacers I can get that will work?
Really need some help finding the right wheel spacers.
Help greatly appreciated.
basketcase0302
Re: Wheel Spacers to run Mags on 69 Ford F250 4x4
Post by basketcase0302 »
=ssteph1984
YOU MIGHT NOT FIND ANYONE WHO WILL RESPOND TO THIS, SO I WILL... :(
You're already dealing with what us older guys have always been known to be called "widowmakers" (split rims are just they've maimed and killed many guys over the years-get rid of them 1st chance you get).
AND YOU WANT TO ADD TO THAT A WHEEL SPACER THAT'LL THROWN THOSE ALREADY PROBABLY OUT OF BALANCE WHEELS EVEN FURTHER OUT OF BALANCE? :eek:
That out of balance scenario will snap wheel lugs like they are 10/24" screws my friend!
I pray you don't live anywhere in Florida as i never want to be following behind that truck! :pray:
Look at Coker Tire and wheel in my old hometown and if you have to buy one rim at a time!
https://www.cokertire.com/
ssteph1984
Thank u much for the information
cep62
Post by cep62 »
I think he wants the spacers for the new wheels , He just measured the split rims back space for reference.
You might be able to get spacers at a good tire store .
I used some 1/4 inch spacers before without issue but if you need a inch that can put a lot of stress on the lugs.
Especially on the front when turning.
ssteph1984
I ended up buying 1 1/2 spacers for front and rear. Running 265 75 16 tires. Hoping this isn't going to put too much strain on the kingpins.
