You need to determine how you want to spend and proceed.
I think the hardest part will be to secure the correct engine brackets and belts that match both the engine and the compressor. The compressor, evaporator, dryer, condenser and rest all would be same as for any bumpside. Suggest that you use the newest refrigerant with compatible components. Make sure hoses are compatible - R-12 is very expensive and government requires a license to work on it. You should have a vacuum pump althouth the compressor itself can be used as a pump! R12 and R134a hoses and ports cannot not be used interchangeably. Also, spend the time to route hoses through the firewall and/or away from other mechanical components particularly the condensate lines. I find many articles on the net. Vintage Air is really popular -
https://www.vintageair.com/basic-auto-a ... sor-facts/
R-1234yf is the latest development in auto cooling systems. It’s being introduced gradually in cars sold in the U.S., first in the 2013 Cadillac XTS and ATS, then Chrysler’s Fiat, and many more models are now adopting this type of refrigerant versus the old version — R-134a. From the net.
If you want to go OEM, I see AC units and components that are either stock or dealer add-ons occasionally on the net. I like the look of factory dash controls. in my "fleet" i have all three types - factory, dealer, and after market.
I do not want to buy gauges etc. so I go to a AC shop for service.
