Anyone know how is comes off?
Ron_Hall
Post by Ron_Hall »
Anyone know how this comes off? I can get the antenna out but the chrome housing seems to be stuck.
Ron
1971 F100 SWB 390 FE - bored.030 over
Edelbrock Performer - Holley 600 CFI
Stock heads with some porting - Sanderson FF427 Headers
C6 with stock converter - 3.25 rear end gears
One owner...
cep62
Re: Anyone know how is comes off?
Post by cep62 »
If it is OEM the chrome bezel prys off and there are 4 screws
If it's aftermarket that might be a big nut on top.
I can't tell from here.
MAK
Post by MAK »
Mine was just a press-in style with no screws. It had a round spring/compression style base that pushed into the hole and the little spring clips applied pressure around the base of the hole to keep it in place.
Ron_Hall
Post by Ron_Hall »
MAK wrote:Mine was just a press-in style with no screws. It had a round spring/compression style base that pushed into the hole and the little spring clips applied pressure around the base of the hole to keep it in place.
Thanks MAK, That's like mine! so, can I just pry it out or do I have to go inside the cab to get it?
Ron
One owner...
MAK
Post by MAK »
Ron
Mine took very light pressureI to pry off. But be careful, yours could be a different style mount and you don’t want to damage the sheet metal.
pcmdub
Post by pcmdub »
The picture shows a nut on the top. I would remove the nut before trying to pry anything on sheetmetal.
After you remove the nut, the chrome bezel "might" come off exposing two self tapping screws. Others just use the nut to tension the entire antenna and mount. I wouldn't pry on sheet metal thou.
