Hey,
Just a quick question. Where is the hazard light witch on a 1979 F250 Extended cab. I think it is the directional switch/lever. Is that correct? if it is, do you pull the directional lever back to the driver to turn the hazard lights?
Thanks for you help
Re: 1979 F250 Extended cab
Any help please
- DuckRyder
Is that a dent side?
I do not think it is the directional, but can’t help beyond that.
- 1972hiboy
Pulling back on the turn signal lever would be for tilting the column up and down if it had the capability to do so. The hazard flasher switch is a stub sticking out of the steering column on the right side at about the 4 o'clock position. It is a push pull switch, you pull it out to turn the 4-ways on and push in towards the column to turn off.
Rich
Dont eat yellow snow.....
