Power brake swap?
Hazmoid
Power brake swap?
Post by Hazmoid »
I recently purchased a '72 f100 custom, it needs a lot of work and I am trying to "prioritize". I would like to install power brakes and front discs, but would like to know if one needs to be done before the other? Also when the new power brake system is installed where will the vacuum line attach to the engine(302), Will any modifications need to be made to allow for the vacuum?
Thanks,
mrsnicks
re: Power brake swap?
Post by mrsnicks »
You also need the firewall bracket. Make sure you get that as everything else can be bought at Advance Auto, AutoZone, etc... but you must get the Power Brake Booster bracket from a donor vehicle.
Patrick
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
Here's a view of the vacuum tree on a 302. The engine in this photo came from a '72 with manual brakes and manual transmission, which is why all the ports are capped off. If the truck had been equipped with an automatic transmission, there would have been a small vacuum line going to one of the smaller ports. If the truck had been equipped with power brakes, the larger port on top (which has a cap in it) would have had a short piece of steel tubing coming from it for the booster vacuum hose.
I've got another picture of a vacuum tree with the above-mentioned tube, but I'll be darned if I can find it. I'll do some more searching and see if I can dig it up. If I do, I'll post it to the Forum Reference Photo Gallery, as well as in this thread.
heres one from my 78 302. Image
sorry about the lighting this camera reqiures more than a light bulb in a room. its best suited for outside.
qman
Re: re: Power brake swap?
Post by qman »
mrsnicks wrote:You also need the firewall bracket. Make sure you get that as everything else can be bought at Advance Auto, AutoZone, etc... but you must get the Power Brake Booster bracket from a donor vehicle.Patrick
What is this bracket? I bought one from a salvage yard and only pulled off the booster. Is the bracket inside the cab?
the bracket is behind the booster on the outside of the firewall.
