You can also go for a drive on a highway with mile markers and compare the distance your speedo says you have driven in ten miles to the actual distance.
If you speedo says you have gone 12.2 miles, but you have only gone 10, then your speedo gear needs 1.22 times more teeth your current gear.
You can find speedo gears at:
http://www.nationalpartsdepot.com/
Look in the online catalog on page 150.
Hope this helps.
