73 f-100, it has discs but no power brakes.
dcv73
Post by dcv73 »
I am trying to find out the best way to add power brakes to this truck. It has discs, but no power or vac booster. Can I just add a booster?
you'll need the booster the bracket for the booster the power master cylinder and probably a propotioning valve unless you already have one instead of a distribution block
heep70
re: 73 f-100, it has discs but no power brakes.
Post by heep70 »
Yep, hit the junk yard and get EVERYTHING from the pedal to the MC. Make sure the MC donor truck has disks.
:wel: to the site. Hit the "Welcome Mat" and intro yourself and your rig. Post some pictures, we like Pictures.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
Yeah, if you're just wanting the add the power to your current disc brakes, you just need the power booster (w/mounting bracket) and the hose connecting it to the engine. However, you might want to also grab the hose nipple on the intake manifold, just in case.
boots
Post by boots »
I know this isnt my thread, but I was wondering if any of ya guys got a pic of where the hose connects to the engine? Ill be hitting a junk yard this weekend to pick up power brake parts.
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
not a pic but it behind the carb on the passenger side of the truck to the manifold. should be a tree with several hook ups for vacuum.
boots
Post by boots »
fordman wrote:not a pic but it behind the carb on the passenger side of the truck to the manifold. should be a tree with several hook ups for vacuum.
thanks alot :D
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
