302 EFI throttle pedal ideas or suggestions
Hello all, i've recently put a 302 out of a 89 mustang into my 68 bump. im having trouble trying to modify my stock throttle pedal to work with a cable operated throttle body. the pedal is too heavy for the throttle body spring to return the pedal after wide open throttle. any pictures or suggestions would be greatly appreciated.
- beejaytx225
Re: 302 EFI throttle pedal ideas or suggestions
Maybe a heavier spring on the return? Or a secondary spring on the pedal arm?
1968 F-100 Ranger LB
360 w/C6
Peacock Blue
Family nicknamed her "Bethany"
Central Texas
360 w/C6
Peacock Blue
Central Texas
- Ranchero50
Just bolt in the stang version of the pedal. ![Wink :wink:](./images/smilies/icon_wink.gif)
iv added an addition spring to the throttle body which has helped drastically. im using Lokar cable made for a mustang, the only real issue im having now is the cable saws slightly on the aluminum housing ends of the cable.
