Drop coils
- morganater
Drop coils
I don't really like the stance of my truck, it is really level. I am not sure about the history or status of my truck coils but they seem to be stock, even with the 460 in the front the truck is really level. I want to order some of the 2" drop coils from LMC tuck. I was wondering how hard these are to install, becuase i really want the RAKED stance. Is this an arduous process involving lots of tools or what? I just want to know whether to order them or not. I really want the raked stance and this is the most viable and easy way it looks like to do it. thanks for the input.
1969 f100 swb ranger 460 - parting out
1968 f100 swb 429 - decking out
94 Jeep I6 Back-up vehicle
reppin' AK
reppin' AK
- cobraF100
re: Drop coils
It's not hard to do at all.
Use a set of Small Block springs.Thats whats in the front of my Truck.I haven't had any problems with running them.
Chris
Never Forget Our Soldiers
- morganater
re: Drop coils
Yeah i've heard it's easy, but thats all i've heard. Does anyone have a walk-through?
reppin' AK
reppin' AK
re: Drop coils
the coil spring is held in place by two rusted bolts and a c clip looking job at the top. I'm not sure the size of the bolt that secures it at the bottom, i use a bigass monkey wrench for stuff that big.
remove the wheel, put the frame on a jack stand. put your floor jack under the kingpin spindle area, remove the upper nuts at the top (thats redundant) then lower the spring. you'll have to get the wrench through the coils, remove it, and take note of the order of part removal. best i can recall, all i had was a rubber bushing, a washer and the nut. thats all it has now. not to hard. assembly is the reverse. i advise using plenty of PB Blaster.
If i've left anything out, please add.
re: Drop coils
2" Drop coils alone won't give you much - most won't even notice the difference. I had "2 drop coils alone for a while and then went to 3" drop beams and 2" drop coils- then it was lowered.
Keith has a good article posted here on lowering.
Trevor Rush
- morganater
re: Drop coils
I ordered the drop coils. They should make somewhat of a difference I think because the former owner of my truck had some new coils put in that have hella strength and it looks like the truck is sagging almost I hate the stance. I will put these on hopefully it will be noticeable. It will be to me at least.
reppin' AK
reppin' AK
re: Drop coils
you could always add a leaf or 2 in the back too. raise the rear and it gives a nicer rake without having to mess with drop beams if stance is all you care about and not distance from the ground
JESUS LOVES YOU! everyone else thinks your a jackass!
- morganater
re: Drop coils
Hmm, yeah thats in interesting idea. turns out they actually DONT have the drop coils. they are discontinued . I sure as hell aren't ordering drop I-beams for 400+++ and installation would be a pitfa. I will see what It looks like after paint, and if i care as much anymore about the stance.
reppin' AK
reppin' AK
- willowbilly3
re: Drop coils
Camber is controlled by ride height on these trucks and if you use shorter springs the camber will go out of specs. 2 inches may not be a big problem but an alignment shop might not be able to set the alignment properly.
- greasemonkey060
re: Drop coils
you could beef up the suspension in the rear, maybe some blocks (if its a axle over leaf setup). and then fill up the space with some bigger tires.
my .02 cents
-brandon
my .02 cents
-brandon
'64 F100 SWB 8" notch, & triangulated four link w/ 2600 Firestone bags out back.
'67 F100 SWB STOCK.
'67 F100 SWB STOCK.
