Non Power drums to Power Drums
- studdmstr
http://cgi.ebay.com/ebaymotors/69-70-71 ... dZViewItem
I just found this and was wondering if it would be worth the money and time.
Currently I have drum/drum non power brakes. What other items would I need to finish the job?
- heep70
Man, You might want to check with NAPA. That looks a little spendy. I am not sure but you might need the pedal.
I think I did mine for $50 out of the junkyard.
Greg
2000 Subaru Outback limited.
2013 Polaris Pro 800 RMK 163"
My last 1971 "Highboy" pics
- studdmstr
re: Non Power drums to Power Drums
Thanks for the ideas. $195 did seem a litltle pricey but they were new parts not rebuilt. I think I'll pass and wait to find a power disk donor.
- hardtailjohn
You're happy with your power drum setup on yours, aren't you Greg? Just wondered if it's worth messing around trying to get all the other stuff gathered up...
JH
JH
Discs are also considered a major improvement if you drive in hilly terrain, or anyplace where you'd be using your brakes more than average. Drum brake setups are notorius for what's known as 'brake fade', which is when your components get hot and loose effectiveness, such as when you're driving down a long downgrade, especially if towing a trailer.
They're not necessary by any means, but my own personal opinion is that they're a fairly inexpensive but worthwhile upgrade, and should be seriously considered, considering the parts are inexpensive and readily available. A great time to make the swap is when you've scheduled your truck for a major brake overhaul or when replacing kingpins.
- rjewkes
Question i got the power Disk front suspension from the 77 is it 100% compatible with the 72 and do i need a different master Cyl.? mine for the power drums has the different sized reservoirs.
fuelly.com
fuelly.com
The entire '77 front end will bolt up to your '72. You should always use a disc-brake master cylinder with disc brakes, in addition to the disc-brake proportioning valve. Both of these components are very different from their drum-brake counterparts and should not be mixed.
- rjewkes
Thanx Keith. I'm hopeing to find a decent frame to start a full off with kinda like with a rod. should be nice when i'm done.
fuelly.com
fuelly.com
- Big D's 69
I'm looking for a doner right now so I can do my swap.
