Looking for a source for 16" "stock" wheels?
xxxtina63
re: Looking for a source for 16" "stock" whee
Post by xxxtina63 »
I think, although I'm not positive, that 94-01 Dodge rams used the 5 on 5 1/2 pattern.
flyboy2610
Post by flyboy2610 »
The bolt pattern is only part of it. The backspacing needs to be the same, or nearly so, as well.
cooltoolguy
Post by cooltoolguy »
try this place www.stocktonwheel.com
72 Ford F-350, 2WD, 4 speed 360, Dump truck
76 Ford F-350, 2WD, Cab and Chassis <--gone
spartman
Post by spartman »
Try your local firestone or tire dealer.
They should have stuff like that.
I know my firestone dealer here can get them.
dotcentral
Post by dotcentral »
I was trying to find something used, not custom. I need to hit the local yards anyway, so I'll check out the 90' ford & dodge trucks. If that's a bust, I'll just save up to get something aftermarket.
spartman
Post by spartman »
What I am talking about is not custom rims but factory replacement rims.
Jake11
Post by Jake11 »
Late model F150's
trickf100
Post by trickf100 »
My 67 f100 came from the factory with 16 in. wheels with the 5x5.5 bolt pattern. They aren't very wide and they used the same hubcaps that the 250's came with.
MOSES
1968 f100 Ranger
1972 f100 Sport Custom
1972 f250 4x4 conversion
