DIY Oil Pump Primer
69-er
DIY Oil Pump Primer
Post by 69-er »
I would like to make an oil pump primer. I don't have a spare/junk distributor laying around to modify. I can see that a 5/16, 1/4" drive socket with an extension fits very nicely in the block.
My question: does the distributor body need to be in place to allow proper oil flow to the engine like a Chevy? I don't see the need but want to make sure.
Thanks again!
Larry
M-100
Re: DIY Oil Pump Primer
Post by M-100 »
The distributor doesn't have to be in place if it's a small block not sure about anything else. You can rent one from AutoZone if it's a small block.
69-er
Post by 69-er »
That's the first place I looked. All that was listed was a Chevy and it's not even available. Same with Oreilly, NAPA and Advance. I'll see what happens with the socket...
M-100
Post by M-100 »
Be careful and don't drop the socket down the engine
69-er
Post by 69-er »
Yeah, the first time I tried it I thought I did! It was just the pump shaft sticking to the socket and falling back down in the pump.
sargentrs
Post by sargentrs »
Just buy a piece of 5/16" stainless hex stock and use your drill. McMaster-Carr sells a 2' piece for about $13.
69-er
Post by 69-er »
Cool, thanks. Thanks easier and safer.
You can spin it with a socket on an extension using a 1/4 drive adapter in dill, tape the socket to the extension.
sparky72
Post by sparky72 »
DuckRyder wrote:You can spin it with a socket on an extension using a 1/4 drive adapter in dill, tape the socket to the extension.
This is what I do.
Taylor
1972 F250 Ranger XLT 2wd / 8100 GVW / 390 / T18 / 3.73 D60
basketcase0302
Post by basketcase0302 »
