What do I do with this
Here is a picture of the bottom of my cab. The eye bolt is in my cab mount
I've done the floors, rockers, a pillars, firewall, etc so I dont want to give up now, but when I started the rear cab corners I realized how bad the middle between the cab mounts is. (Its worse than the picture shows) Anyone got any tips for tackling this? Not much to weld to, might be using por-15 and body panel epoxy. Not looking for pretty, just solid.You do not have the required permissions to view the files attached to this post.
1972 f250 4x4 390 4speed
Re: What do I do with this
Well LMC has a cross member for $150.
Or you can get some light cardboard or heavy paper ,and cut and paste up a template.
Take it to a fab shop and see what they'll charge you for some metal.
if you're handy you can cut your own pieces and save some money.
It's not the crossmember, here's a better picture
It's the very back of the cab under the fuel tank shelf.You do not have the required permissions to view the files attached to this post.
- jzjames
No easy way out. You just gotta fab and weld a new piece.
Your floor repair looks nice ,
working in that position shouldn't be that bad.
measure carefully before you start cutting.
Cut out the bad last night, much less intimidating than I thought it would be, here's what it looks like underneath
There were two rusted out layers, the bottom of the cab and then a u channel frame below that which held the cab mount spacer. I'll patch the floor then recreate the u channel and cover it with another sheet. No one will ever see it. You do not have the required permissions to view the files attached to this post.
- jzjames
Good job. You saved the threaded holes for the seatbelts/seat runners (?)
- sargentrs
Great work and thanks for showing us!
Finished the outer panel with 16ga metal, reused the original spacer for the cab mount and everything lined up great. Only thing left is to put the seatbelt nuts back on.
- sargentrs
- cstoyer
Sometimes you just dive in and figure it out as you go. but obviously you have skill by your previous repair work.
68 F250 4x4
