I have a gremlin in my wiring and was wondering if there is any commonality with horn, turn signals, and high beam lights?
One by one, things are dropping off. In a very preliminary look, no signs of damage by age or rodents.
Help would be greatly appreciated
Gremlin in wiring
Gremlin in wiring
- basketcase0302
Re: Gremlin in wiring
Other than bad grounds to all three, (separate) circuits there isn't really a common single point to make all three fail at once."KulpFarm"]I have a gremlin in my wiring and was wondering if there is any commonality with horn, turn signals, and high beam lights?
![Sad :(](./images/smilies/icon_sad.gif)
The horn will usually be at the brush under the steering wheel / turn signals usually either bad grounds or the switch / and the high beams will usually be due to the dimmer switch on the floor.
What year bump?
It’s a 1972
- basketcase0302
This might help in the future:
![Image](http://www.fordification.com/tech/wiring/wiring-diagram-72_quick.jpg)
I also recommend getting one of these, (I kept mine rolled up in the dash pocket) as they are a lifesaver out on the road when electrical gremlins come up. I didn't see the one for your 72' but pretty sure they'd have it. Maybe send them an message to confirm as it will save you a lot...of money and time!
https://www.ebay.com/itm/1971-71-Ford-F ... 546d260f92
- basketcase0302
basketcase0302 wrote:Other than bad grounds to all three, (separate) circuits there isn't really a common single point to make all three fail at once."KulpFarm"]I have a gremlin in my wiring and was wondering if there is any commonality with horn, turn signals, and high beam lights?
Help would be greatly appreciated![]()
The horn will usually be at the brush under the steering wheel / turn signals usually either bad grounds or the switch edit: also look for the flasher as it is a common fault problem(up under the dash) / and the high beams will usually be due to the dimmer switch on the floor.
What year bump?
