ok, so as i pulled into work this morning (well, technically last night... graveyard shift... but anyway) i found that when i turned the steering wheel, it didn't turn the tires at slow parking lot speed. come to find out, the steering shaft stripped out on the uphill side of the first u-joint coming off the steering box. so, my question is, what year shafts will interchange with my '68 power steering setup? i think i read somewhere that '67-'77.5 would fit, but i think that was for manual steering setups, and since i know a lot more about Toyotas than about Fords, i wasn't sure if the same year range applied for power setups...
here's a picture of what stripped out...
![Image](http://www.imagestation.com/picture/sraid201/p2f34b007a0061657cdd5d82f6766feca/effcf452.jpg)
i'm heading out to take it off right now, and see if it's fixable, and if not, off to the junkyard to see what i can find, i was just hoping you guys could point me in the right direction as to what to look at
thanks!
