Correct air cleaner for 1970 F-250 w/ 360 FE
timachone
Post by timachone »
Hi guys,
could anybody provide pictures of a correct air cleaner for the 1970 F-250 with a 360 FE?
I have a feeling that I have not the correct one... It has a closed PCV inlet bow in the front and a clip in the left side where the PCV hose routes now. In the back there is a quadratic hole of something but the something is not there. The snorkel seems like a right one. Could this be an air cleaner from another ford car?
Thank you,
Tim
Tim :drive:
1970 Ford F250 360 FE 2V C6
2012 Ford S-Max 2.0 EB AT
MAK
Re: Correct air cleaner for 1970 F-250 w/ 360 FE
Post by MAK »
A picture might help, what is a quadratic hole? 70 can be a bit of an oddball too.
timachone
Post by timachone »
MAK,
thanks for the hint. Nice sample of a low mile truck :thup:
It seems I have a wrong one on the carb. Perhaps a 68/69 air cleaner from a passenger car...
Could anybody confirm if there are any other lines to or from the air cleaner other than the pcv-valve tube? Some vacuum lines for example to a temp control switch? Or did they have a fuel carbon canister outlet? In the pictures of the mentioned truck it seems that there is a hole closed on the left...
Could anybody provide a production ID of the snorkel to identify the correct one?
Thanks,
Tim
Tim :drive:
