Starter wont engage
ebaby35
Starter wont engage
Post by ebaby35 »
Bought a new starter flip switch and hear it but not engaging ring gear. Could it be the solenoid is bad or car battery doesnt have enough juice?
bluef250
Re: Starter wont engage
Post by bluef250 »
Does solenoid click or rattle or nothing? Does the starter run? If not load check the battery and all connections - positive and negative.
ebaby35
Post by ebaby35 »
Bought a new solenoid and kinda clicks now so thought it might be the battery. I try to jump it but just sparks at solenoid.
bluef250 wrote:Does solenoid click or rattle or nothing? Does the starter run? If not load check the battery and all connections - positive and negative.
dtcohen
Post by dtcohen »
Could be the wrong starter. There is some confusion. About the ford manual vs automatic starters.
sargentrs
Post by sargentrs »
Check your other wires on the battery side of your solenoid. Especially the brown one from the alternator. I struggled with mine not starting one time and discovered that wire had a bad crimp at the ring terminal. Didn't notice it until the 3rd time I pulled the solenoid and the ring pulled off the end. Crimped a new terminal on it and she fired right up.
Also make sure you have a good ground where the solenoid bolts to the inner fender. Those sheet metal screws don't always hold their grip. I drilled through and put bolts, star washers and lock nuts on my to make sure I had a good ground.
