What is this gasket called on the driver side on the 300 I6 engine? Any recommendations on where to purchase this gasket (and the bolt rubber washers) separately from an entire engine gasket kit? Thanks!
Engine Gasket Question
- Idaho Chris
-Chris
1969 F250 4x4 4spd 300 I6
1973 Mustang Mach 1 351C
- colnago
Re: Engine Gasket Question
Is that the valve cover gasket? Your best bet is probably your local AutoZone, NAPA, etc. If not, then check with Rock Auto, LMC Trucks, or NPD Link. Finally, Amazon or ebay.
Joseph
Joseph
- Idaho Chris
No, not the valve cover gasket. It is on the side of the block below the head behind the distributor. I am presuming it gives access to the lifters, but since I have never seen a 300 apart I do not know. If I can figure out what to call it I can search for a gasket...colnago wrote:Is that the valve cover gasket? Your best bet is probably your local AutoZone, NAPA, etc. If not, then check with Rock Auto, LMC Trucks, or NPD Link. Finally, Amazon or ebay.
Joseph
-Chris
- phantomtruck68
They are called the push rod covers. Autozone part # PS10603C.
Joe
My Phantom truck
1968 F250 4x4
390 FE, bored .030, Crane 272 cam, 600cfm Edelbrock carb.
My Phantom truck
1968 F250 4x4
- Idaho Chris
Thank you Joe! I knew they couldn't be called Lifter Covers since my search with that term yielded zilch...phantomtruck68 wrote:They are called the push rod covers. Autozone part # PS10603C.
-Chris
- phantomtruck68
Not a problem. Just passing on a little knowledge left in this noggin! LoL.
Joe
My Phantom truck
1968 F250 4x4
My Phantom truck
1968 F250 4x4
- colnago
This is why I love this group; I am ALWAYS learning something new.
Joseph
Joseph
- jzjames
When you re putting in the new gasket and donuts, be sure to “eyeball” the side cover for flatness. They can get distorted from over tightening and a little careful “massaging” of the cover to get flat and true can go a long ways to prevent any leaking.
