I am sure this has been asked, yet doing every search I can think of does not answer my questions.
I am been blessed to have my 1969 back. (It was gone for five years). Now that I have it back, it has been sitting that entire time in the harsh Louisiana weather (extreme heat, high humidity, rain, etc.) and every tire is rotted. I am having a hard time locating 15 inch rims that fit and 235/75/R15's as well. Not being versed on tire and rim sizes- I figure I would call upon those of you who know these things.
Standard issue 1969 F100 LWB. 15" rims that 5x5.5 with a standard tire size of 235/75/R15.
Would a compatible 16" rim also be 5x5.5 pattern? If so, is there a vehicle out there that has that pattern? Perhaps a ford or dodge truck that has a 16 inch rim that will bolt right on with no adapters?
Or- is there another 15 inch tire that I can put on a 15 inch 5x5.5 rim that will work? Obviously not every 15 inch tire will fit- am I correct in thinking that? I do have enough old 15 inch rims that I can clean up and plasti-dip to look half way decent. I just do not know what other sizes would fit...I am thinking that 265/75/R15 would fit on the rim and work, but have no prior experience or knowledge to know if that is correct.
Well, there it is. If you know, I thank you in advance for your time and attention to these questions.
1969 F100 compatible rims/tires
- 69F110
Steve Davis
Pastor and U.S. Army Retired
1969 F100 Ranger LWB, 390 and 3 on the tree
- HIO Silver
Re: 1969 F100 compatible rims/tires
Wheels from half-ton Econolines should fit the bill... both 15- and 16- inch varieties.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
If you are looking for OEM wheels, any F-150 or Bronco wheels up until 1996 have same lug pattern. As HIO Silver mentioned E-150 wheels fit as well, but I don't know what year they changed.
1968 F-100 4x4 long bed - 360 FE - NP435 w/ Dana 21 - PS & PB conversion - Front Disc Swap - 265/75R16 - 1" S.L. & 2" B.L. (to be removed) - Homemade tube bumpers - Warn 8274 - Currently wearing 1970 body
Another option you could go with like I did is this.......
https://www.wheelvintiques.com/o-e-chev ... inish.html
They look just like stock rims and come in different widths - I went with 15X8's with 31-10.5's on mine mostly to help drop the rpm's a little........I have a picture of them unmounted and mounted in my gallery......
As far as tires I went with these......
http://mastercrafttires.com/Tires/Light ... r-LTR.aspx
They make these in a 235/75-15 and I have had pretty good luck with them........don't know if they sell Master craft down your way though.....![Confused :?](./images/smilies/icon_confused.gif)
1997 Honda CBR 900RR
