Bought a used speedo to put in my 68 as my odometer quit working. Worked great first couple days. Then it got cold. In the morning last couple days it made a heck of a racket, you could hear it was a rotational sound. Needle would fly wildly around the dial. However on way home when warmer no noise and worked fine. I was going to look in to it this weekend but this morning it made way more noise. Needle went nuts then buried itself on the low side completely out of sight and stayed there. I'm fearful to lube anything as don't think the speedo or odometer take lube. Looking for any ideas.
Any suggestions?
Speedo issues
Speedo issues
1968 F100 SWB Flareside, 240-6, 3 speed, 3.70 rear, bone stock and rust free.
- basketcase0302
Re: Speedo issues
The cable assembly takes spray lithium grease. Unscrew it from the speedo housing and spray down the cable sheath. But it sounds like your gonna find the end of the cable eaten up, (possibly something in the speedo bound up or more than likely the plastic gear on the tranny end seized causing the cable to bind)."takehikes" Bought a used speedo to put in my 68 as my odometer quit working. Worked great first couple days. Then it got cold. In the morning last couple days it made a heck of a racket, you could hear it was a rotational sound. Needle would fly wildly around the dial. However on way home when warmer no noise and worked fine. I was going to look in to it this weekend but this morning it made way more noise. Needle went nuts then buried itself on the low side completely out of sight and stayed there. I'm fearful to lube anything as don't think the speedo or odometer take lube. Looking for any ideas.
Any suggestions?
Here's a good image of the cable less the plastic gear on the tranny end that connects using a c-clip:
![Image](http://cdnll.dennis-carpenter.com/images/xxl/C5TZ-17260-N.jpg)
Re: Speedo issues
Lubed cable and it works fine with no noise. Odometer still working but speedo needle is buried completely out of sight and hasnt moved.
Not sure whats going on.
Re: Speedo issues
What is the correct length for the cable?basketcase0302 wrote:
1969 F100, 390, 3 Speed, 2WD
- basketcase0302
Re: Speedo issues
I don't think there could be any thing else here but a bad gauge, (if the odometer is still logging miles and the speedo is buried)."takehikes"]Lubed cable and it works fine with no noise. Odometer still working but speedo needle is buried completely out of sight and hasnt moved. Not sure whats going on.
And the DOT basically made them tamper proof so we could not roll the miles back, (legally).
![Image](https://cdn.shopify.com/s/files/1/0563/1781/products/image_06a0b86b-5749-4619-9525-06392404cd36_1024x1024@2x.jpg?v=1500272260)
I've got a cable here but will have to dig, (it's in the bottom of four heavy very large boxes of parts) to measure.
Maybe someone else can come along that has one easier to measure pchelp101.
![Pray :pray:](./images/smilies/icon_pray.gif)
