![Image](http://i1118.photobucket.com/albums/k607/monkeystash/D1CADF25-67A3-450B-9BE4-ECB24137C3BC_zpsw7ryvu3a.jpg)
Picked up my CV off Craigslist.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/76A74C5F-0077-4332-AB71-B46C7A01C01D_zpsgly0aagi.jpg)
Got it all tore apart and cleaned up.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/C39CF58B-9174-4C0D-ACD3-3FDF6EC0C67C_zpseip0hgzw.jpg)
Started pulling the truck apart, early Sept 2017.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/8A815757-3478-471E-AF0E-C84EA75CBB2F_zps5ogqpq2l.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/26018861-EEEA-4D26-ABEE-A58AB1EE3D53_zps1vus6e3s.jpg)
Pulled the motor and trans out together, then sold them. I'm not 100%, but leaning 6.0 LS.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/387ACCC2-6E31-4E15-B9C8-4DBFDDF6D354_zpsqtxgcdtd.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/9ECEB4CC-1578-43A8-863B-DDA058B61224_zpshjsaa2iw.jpg)
Pulled the front suspension off and sold the I-beams, brakes, and wheels.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/80C199EF-131D-49CE-BEEB-A9DB52769C62_zps26fb3xjq.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/EDAF2C80-F67C-4888-8A3B-93ECB34DF052_zpsap2mq2yn.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/9F3EC65E-0659-445C-BE79-329B39724043_zpsiozjqzcw.jpg)
Braced the frame and started with the horrible task of removing rivets. Got the spring towers off.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/3CC8A0A8-231D-408F-89C2-C87E253E9C84_zpssedcoik0.jpg)
Cut the crossmember out. I thought this would be the worst part, but a 4 1/2" angle grinder did most of the work and I was pleasantly surprised how well it went.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/24589372-773A-47A0-878A-A6A171E0E8CC_zpsshmtv5dg.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/2730EC5F-00DE-40E3-9C70-A16AD26E2273_zpssyhfwsuu.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/AEE5AE2E-D5EE-4A58-982E-1EDB3E251151_zpsxw19qcs5.jpg)
Assembled the CV off the car with all new parts. Notice the 14" rotors and Corvette C6 calipers. I saw this upgrade on the Marauder forum and its a cheap upgrade.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/E8F8FBA0-E2BE-404C-9B8B-F653ACA2F8C4_zpsp7z5zlmh.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/EB167018-A28E-4779-A2BF-01A723983664_zpsexxcktwp.jpg)
Measured a million times and drilled...and somehow still being off a hair.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/CFAA7115-ED5E-49C6-AF80-0A51955C60EE_zpsfhmt7hsg.jpg)
Bought new sleeves from Ford and drilled holes for them.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/92609EC9-E303-4835-BD4E-FD9006E95A07_zpsd83nzn6z.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/E2700CBD-459B-4A85-8B31-77DE3509D328_zps1rwmxj6m.jpg)
Checked that it all fit and burned it in.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/693A77B6-0983-4A91-9BD0-23C4134FAC80_zpsp42xtk9j.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/60CBE2A0-576B-45B5-8AE6-681279DC8E36_zpsbbwxmjnr.jpg)
Painted the frame back to the cab.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/6D3835D7-D295-457A-90F1-753229B8470B_zpspcnzg0dd.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/C83E586A-2661-4D1D-A269-9D34B7981784_zpsuncdfrvo.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/FBAB9915-D592-46EC-8CBA-CBF79E1BBD3D_zpsgl3mkgef.jpg)
Picked up these Mustang GT/CS 19" wheels. I wanted black wheels and I think these will look sweet.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/62F3A4E8-2F96-426A-9D60-6016A299223A_zps7ewlsptn.jpg)
Bought an 8.8 out of an '01 Explorer with 3.73 posi. Had to pull it myself, but for $75 it was a no-brainer. I tore it apart, replaced the axle bearings and seals, installed the Ford Racing carbon clutches, replaced all the brake parts, and made it pretty.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/B449E70E-3F79-4BD1-A2E1-44554C0BC1C2_zps1e4u7hpx.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/8A85B0E1-A322-47EA-B852-3B5D87D049DF_zpsdyi7gbh4.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/604726F3-A416-4380-A3D0-0C2DC1B431BB_zpsiom75wqm.jpg)
Upgraded the u-bolts to 5/8.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/827E53C2-D9D1-40ED-866D-E15CBE771401_zpsmnzmytns.jpg)
Because the perches are slightly narrower than the 9" I chose to redrill the holes instead of cutting off the perches or bending the springs in. Stuck a 1/2" copper pipe in the new hole and welded up the other.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/2657B85E-9959-41CC-B14A-9ECA548F3F60_zpsdx36zmss.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/2CA674DD-2047-4386-8789-107A02ACDBE0_zpsyj8m7wal.jpg)
Bolted the 8.8 in. Notice the slightly offset perches. Still contemplating a c-notch, although I'll probably go ahead and do it.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/51F1C8A8-3643-49FD-BE08-A97A18204223_zpsendigmla.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/332C753A-FB3A-4794-8D57-14B44E6BD3D9_zpsagkm1rxi.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/7E750E67-07EA-404D-8BC5-2776B3B81DE8_zpsvsqdzbrh.jpg)
Looks like I'll need some shims.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/5F4C7488-E0BF-4398-9D07-C386CE540511_zps2v8ftfng.jpg)
Bought a Tanks Inc EFI Mustang 22 gallon tank with internal pump and baffling. I made a 1" tube frame for it and initially mounted the tank on top on the frame. That however made the tank sit too high in the frame rails. So I mounted the frame on top and now the tank is sandwiched between the frame rails and the tank frame. I welded a bracket to the front and now it all bolts in with J-nuts. The rear of the tank frame also has J-nuts and it bolts directly to the frame from the bottom. I also had to modify the rear crossmember and weld nuts inside it. There isn't a good way to get a wrench back there, so now I don't need to. I will have to also weld nuts in the frame for the bumper brackets.
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/86D00502-9125-4609-865E-C3B4BCEAAB62_zps9d1nytl7.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/44C40C9C-BF18-44BD-B21F-6ED3C9735950_zpskqrinje8.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/8F5F6AEC-2D8F-4C79-AA3A-8E7A27C7D457_zpsi04cysyf.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/301A80F1-C8EB-4988-89DE-DA1B78551650_zps689iows0.jpg)
![Image](http://i1118.photobucket.com/albums/k607/monkeystash/876DBCB2-59EC-46EF-8094-10427F448431_zpswz0vkd6g.jpg)
Hopefully this week I can get the rack mounted and start working on the steering shaft and u-joints.
