paintjob
paintjob
im just tryin to get ideas for a paintjob/color scheme for my truck, its a 1970 f250 2wd, and i am making it a rat rod.. the truck itself is going to be flat black, but as for the color for the wheels and the pinstriping ( i can do pinstripe art) i cant think of what color i should use. so any ideas would be welcome thanks __ jeff
"NOTICE, Insanity has replaced all reason in the design and construction of this vehicle"
1970 F250 Sport Custom, 360FE
1964 Thunderbird, 390FE, Offy intake, holley 4bbl,cam, open exhaust
- LilJack
Flat black? I would think dark red would go good for the pinstripping.
My Teardrop camper
http://www.wcscrc.net/teardrop.htm
72 F100 Custom
http://www.fordification.com/galleries/ ... ?cat=10294
72 F100 Custom
- flyboy2610
re: paintjob
I was just thinking the same thing.
- 1970F250
re: paintjob
for old time looks red works for the rims and white walls, to add some looks slap on some cheep beauty ring and some chrome lugs.
Personally I dislike white wall tires. & like black or gun metal metallic wheels with beauty rings and chrome lugs, with a performance tire letters out, & lower profiles on the front.
For pin strips I cheat and get peal and stick red flame pin stipe it about 3/4" wide and put it over silver or white pin tape. Also you need a windshield decal, the flaming white ford one from Wallmart works. And don't forget a V8 sticker thats important.
And 6" or so to your shifter and add a 8 ball If it can be seen from the front of the truck that is the best. The cheep fluffy red seat adds an interior touch. Along with bare metal floor pans with Black Kight roof Patch, Available at Home depo. & some cheep black floor mats.
You should also think about the spark plug in the rear of your tail pipe.
Pull out your choke stomp the gas add 12v and blow some flames!
Man how do I add pics.
WHAT ?
re: paintjob
And there you have it, that is about as old school as it get's you forgot !fuzzy dice
- binder56jd
re: paintjob
ya'll forgot about the blonde w/ ponytail,chewing gum and bobbie socks
jd
now serving #235
now serving #235
re: paintjob
http://www.tnga.org/Navigation/frames.html ( go to tech section) <home built flamethrower kit,, thats whats goin on mine..
- wt4speed#2
- Buzzy
red candy with tribal flames
owner of
1967 F100 prostreet
1978 Lincoln Mark 5
1995 ford f150
1988 500hp Mazda rx7 convertible
1984 650hp mazda rx7 coupe (added a bigger Turbo)
2003 Mercedes c230 Kompressor
http://www.cardomain.com/id/iambuzzy
http://spaces.msn.com/buzzysweb/
1967 F100 prostreet
1978 Lincoln Mark 5
1995 ford f150
- Kiamors
re: paintjob
Red has been done and done again. It does look good, don't get me wrong, but I would personally want something a little different. I'm thinking Bright Orange or Bright Green like Ladz said. Course you could do white or some kinda light color. but I still think Bright Orange would be awesome. Especially with some fat lines down the side along the bottom or where the trim was.
- dolinick
