Engine wiring harness
I bought a 1969 f100 with a 360. It had an engine fire and the wiring harness needs to be replaced. I've searched but can't seem to find anyone the sells just an engine harness. Any
Help would be much appreciated.
Re: Engine wiring harness
I bought one for the same reason for my 69 f-250 with a 390 from Greens. The part # was C7TZ-14258-Y.
Here is a link to the info I received from Ford parts veterans regarding this harness.
http://www.ford-trucks.com/forums/14680 ... st16823712
Worse case scenario, my original harness is very easily repairable if you're interested.![FORDification Rocks! :fr:](./images/smilies/icon_FORDification.gif)
1967 F-100 4x4 custom cab.
- DuckRyder
I used one for a 390 mustang on mine, works fine and IRRC looked identical.
Out of stock.Busboy wrote:I bought one for the same reason for my 69 f-250 with a 390 from Greens. The part # was C7TZ-14258-Y.
Yes I'm interested. PM?Worse case scenario, my original harness is very easily repairable if you're interested.
Can't find that online either. Did you buy it new? Part number?DuckRyder wrote:I used one for a 390 mustang on mine, works fine and IRRC looked identical.
- DuckRyder
i did buy it new and probably from mustangs unlimited or NPD. Part number no idea ... but it was probably this one:
http://www.mustangsunlimited.com/Mustan ... ustang.axd
I guess I need to dig into it. I was assuming it was all one harness in the engine compartment. Maybe there are three or four separate ones. Engine guage feed harness, Alternator harness, headlight harness, ignition harness?
- DuckRyder
Maybe show us what you need, I think the ALT harness is separate, not sure what you're calling the ignition harness and I'm pretty sure the headlight harness is part of the main harness...
Think I'm going to move this to electrical, you might get some better help...
Pattherat wrote:I guess I need to dig into it. I was assuming it was all one harness in the engine compartment. Maybe there are three or four separate ones. Engine guage feed harness, Alternator harness, headlight harness, ignition harness?
The gauge harness is definitely a separate harness as it only feeds the gauge senders and ignition coil. It plugs into the dash harness right above and behind the ignition switch.
Also, the picture of the harness for the mustang sure looks to be the same to me.
I don't know what I need yet. I was just hoping to get all the parts ordered before I dig into it. The engine fire pretty much cooked everything not metal. Here's a pic:DuckRyder wrote:Maybe show us what you need, I think the ALT harness is separate, not sure what you're calling the ignition harness and I'm pretty sure the headlight harness is part of the main harness...
Sounds good, Thanks for the help.Busboy wrote:Also, the picture of the harness for the mustang sure looks to be the same to me.
This right? http://www.mustangsunlimited.com/Mustan ... ustang.axd
That sounds like the perfect excuse to buy a parts truck.Pattherat wrote:The engine fire pretty much cooked everything
http://www.fordification.com/forum/view ... 11&t=83706
not sure what he has left, but when i met him, he had several dash harnesses. located in canada
67 f100 429 c6
65 meteor rideau
05 crown vic
13 edge
09 H-D sportster 1200c
65 meteor rideau
05 crown vic
13 edge
Try part number D0TZ-14289-K, I just picked up one off eBay, fits from 69-70 360-390 engine . Hope this helps
