Backup lamps not working
- shortbedCUSTOM
Well, after sorting out my taillight issue it's time to move on to the backup lamps. I've read thru quite a few threads on here about how to remedy this and most of the threads point to the safety neutral switch, but after looking into my truck I became aware that my truck doesn't have a safety neutral switch. I've looked at the end of the column (engine bay), and under the dash. I don't see it. Is there somewhere else it could be?
My truck is a '68 Ranger. 302 with an automatic. Column shift.
-carlos
- sargentrs
Re: Backup lamps not working
Unless something's been swapped or modified, it sure be here http://www.fordification.com/forum/view ... hp?t=53527
- MadJoe
Agreed, it's really obvious. When I was looking for mine because the lights came on between P and R, I set my parking brake and moved the gear selector while looking under the dash... then proceeded to slap myself in the forehead when I realized how obvious it was and hadn't needed to go through all that.
1971 F-350 DRW SWB Stake Body
360 FE
C6 transmission
OEM disc brakes
OEM power steering
Dana 70 4.10 rear end
360 FE
C6 transmission
OEM disc brakes
OEM power steering
- shortbedCUSTOM
-carlos
- shortbedCUSTOM
Wow, I just went thru a couple of my catalogs and these things are $100+. Gonna have to hit the salvage yards soon.
-carlos
!!!What is that in the photo?
Wanna-be Rat-Rod: 1971, F-103, SWB, 302, 3 Speed on Column, Holley 7448-2, Headers without mufflers,
Planned Upgades: Holley 1850, Alum. Intake, Lighting Heads, Airbrushed Hood etc...
"On a not so quite night u can hear my Truck Rust!!!!"
- shortbedCUSTOM
That's the mounting holes in the steering column for the neutral safety switch.
-carlos
- sargentrs
CG Ford Parts has them for $50. https://cgfordparts.com/ufolder/fordpar ... TZ-7A247-A and the selector pin for $12 https://cgfordparts.com/ufolder/fordpar ... TZ-7B097-B
- shortbedCUSTOM
- MadJoe
Related question: Is my neutral safety switch only supposed to allow the truck to start in Neutral, or is it also supposed to work in Park? Because my truck only starts in Neutral (1971 F-350 DRW) which isn't a big deal, it passed inspection anyway, and it's sort of like an anti-theft ignition kill switch in that no one seems to know that it works that way until I tell them, but because I'm lazy and a creature of habit I'd like to be able to start it in Park if I could.
360 FE
C6 transmission
OEM disc brakes
OEM power steering
360 FE
C6 transmission
OEM disc brakes
OEM power steering
- sargentrs
Should start in park also. Try holding up on your shift arm while you try to start it. If it starts, the NSS needs adjusting. If not, suspect a wiring issue.
