Skyjacker and Dana 60
I posted on the Facebook page also but here's my 71 f250 so far. This pickup used to be perfect but I've neglected it for some time. I just tore out the whole front end and here it is with 4" skyjacker springs and hi pinion 60. No motor. This dramatically changed the height and width of the stance. Other than having the front crossmember remade and having to cut on it a little to make it fit this was a totally painless process so far. I have not hooked up the steering yet but I have a 3" drop pitman arm and it looks like it should work perfect. Other than that it just needs brakes. Next will be the rear and 14 bolt. I guess I won't be posting pics because it says my files are too large so you can check it out on the Facebook page
