What ATF to use in Cruiseomatic?
Ren
Post by Ren »
I don't like automatic transmissions. Never have. Unless I have trouble with my left leg or my right arm. Which almost never happens.
I've known for a long time that one does not simply pour any ATF into any automatic transmission.
I've heard somewhere that older automatic transmissions that have been rebuilt after a certain year have a different friction material in the clutches to make them more compatible with modern fluids.
Here's the facts regarding my situation:
To the best of my ability, I have determined I have a Cruiseomatic.
I have a receipt showing the trans was rebuilt in 2-'94.
The dipstick has been cut and modified so that some information has been removed. It reads as follows:
(information cut away)ON II AUTO TRANS FLUID ONLY 1257013 M.
What ATF should I use?
HIO Silver
Re: What ATF to use in Cruiseomatic?
Post by HIO Silver »
If a post-80 trans and it has been rebuilt, I suggest Dexron II.
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
ThinLizzy13
Post by ThinLizzy13 »
Pre 78 or 79 C6's used type F trans fluid. I believe the FMX trans used it as well. That's most likely what your trans uses unless they changed the internals.
'63 F100 Uni 223 3OT
'67 F250 CS 352 4Spd
Ren
Post by Ren »
Here's more info I should've added to the original post:
According to the numbers on the trans, which I have researched, it is meant to be attached to a '67 with a 352.
As mentioned before, the trans was rebuilt in 1994.
Would ATF labeled Dexron III/Mercon likely be OK?
sargentrs
Post by sargentrs »
My '64 Fairlane has a Cruise-O-Matic and uses Type F only. If the transmission was rebuilt to the original specs with original style parts, then nothing but Type F.
Ranchero50
Post by Ranchero50 »
You can run what you want. Type 'F' was the spec back in the day. WalMart still carries it. I think it has different friction modifiers in it vs the new stuff.
BobbyFord
Post by BobbyFord »
Dexron allows for more clutch pack slippage. Type F is the more "grabby" fluid. You will never notice the difference with a stock truck/stock trans.
