I have a little bit of a electrical problem with my truck.
My brake lights do not work, my lights in general are fine, they are not burnt out, none of the fuses are out, and my brake light switch on my master cylinder has power, I do not know if the power is just not getting to the lights or what, but i have tried many things and still can't get my brake lights to work, If anyone knows how to fix this problem, it would be greatly appreciated
1965 Ford F-100 Brake lights
Re: 1965 Ford F-100 Brake lights
Welcome to the site.
The brake light goes from the switch up the steering column to the turn signal switch, then it gets sorted out where to go .
do your rear signals work ?
Sometimes playing with switch can make them work, otherwise you'll have to pull the wheel off and investigate.
